Discover the perfect blend of protection and sustainability with the OtterBox React Series case. Designed for the environmentally conscious, this protective cover is made from over 50% recycled plastic, offering a durable solution to safeguard your cell phone. Its ultra-thin profile and soft touch edges provide a seamless user experience, ensuring your device is protected without adding unnecessary bulk. The case is rigorously tested to meet MIL-STD-810G 516.6 standards, offering superior protection against drops and scrapes. Additionally, it supports wireless charging, allowing you to power up your device without removing the case. Choose the OtterBox React Series for a protective cover that doesn't compromise on functionality or environmental responsibility.
Eco-friendly design
Crafted with more than 50% recycled plastic, this protective cover not only safeguards your cell phone but also supports environmental sustainability. Its one-piece design integrates seamlessly with your device, offering a slim profile without compromising on protection. -
Advanced protection
Engineered to meet MIL-STD-810G 516.6 standards, the OtterBox React Series case provides superior drop and scrape protection. Soft touch edges ensure a comfortable grip, reducing the risk of accidental falls. -
Wireless charging compatible
Enjoy the convenience of wireless charging without removing the case. Its ultra-thin design supports wireless charging, ensuring your cell phone stays protected while powering up.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.158 cm x 1.139 cm x 16.775 cm
- 33.35 g
- Material
- Recycled plastic (more than 50%)
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- 7 years warranty
- Designed For
- Google Pixel 9 Pro XL
- 8.158 cm
- 1.139 cm
- 16.775 cm
- 33.35 g
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, scrape protection
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges
- MIL-STD-810G 516.6
- Limited warranty - 7 years
- Designed For
