OtterBox React Samsung Galaxy S22 Ultra - clear
Quicklinx: GVD6WS00 Mfr#: 77-86644
Product Range: OtterBox React Series
£10.79 ex VAT
£12.94 inc VAT
React Series is an ultra-slim, resilient OtterBox case that protects your phone from drops and scrapes. Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip. The case installs easily onto your phone and it slides in and out of pockets seamlessly. OtterBox is known for its stellar customer support and industry-leading warranty. Wrap your phone in the trusted protection of React Series.
  • Enhanced durability
    Crafted from polycarbonate and thermoplastic elastomer (TPE), this protective cover offers robust protection against drops, meeting the rigorous MIL-STD-810G 516.6 standards. Its durable construction ensures your cell phone withstands the challenges of daily use.
  • Wireless charging compatible
    Designed with convenience in mind, the OtterBox React Series case supports wireless charging, allowing you to power up your device without removing the case. This feature ensures your cell phone stays protected even while charging.
  • Ergonomic design
    The one-piece design of this back cover not only facilitates easy installation but also features raised edges to protect your screen and camera from scratches and drops. The soft-touch finish provides a comfortable grip, enhancing the user experience.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
8.29 cm x 1.24 cm x 16.34 cm
Material
Polycarbonate, thermoplastic elastomer (TPE)
Clear
8.29 cm
1.24 cm
16.34 cm
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection
Cover Type
Back cover
One-piece design, raised edges, wireless charging support, 5G compatibility
Cover Features
Soft-touch
MIL-STD-810G 516.6
Lifetime
Brand: OtterBox
