- ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
- HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
- TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
- KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
- Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
- EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Slim design
The ultra-slim profile of the OtterBox React Series case not only adds minimal bulk to your cell phone but also effortlessly slides into pockets and bags, making it the perfect choice for on-the-go protection. -
Durable materials
Crafted from polycarbonate and polyurethane, this protective cover offers a robust shield against daily wear and tear, ensuring your device remains in pristine condition. -
Enhanced protection
Featuring raised edges, the OtterBox React Series case provides extra protection for your device's screen and camera, reducing the risk of scratches and damage from drops. -
Wireless charging compatibility
Designed with convenience in mind, this back cover supports wireless charging, allowing you to power up your device without removing the case.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polyurethane, polycarbonate
- Black crystal (clear/black)
- Designed For
- Samsung Galaxy S21 FE 5G
- Package Details
- Pro pack
- Material
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Wireless Charging Standards
- Qi
- Cover Type
- Back cover
- Ultra-slim, raised edges, wireless charging support
- Designed For
