OtterBox React Samsung Galaxy S20 FE 5G - Clear
Quicklinx: G4FPWS00 Mfr#: 77-81298
Product Range: OtterBox React Series
£10.15 ex VAT
£12.18 inc VAT
  • ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
  • HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
  • TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
  • KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
  • Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
  • EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
Material
Plastic
Clear
Samsung Galaxy S20 FE, S20 FE 5G
Material
Plastic
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Qi
Brand: OtterBox
