- ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
- HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
- TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
- KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
- Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
- EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Slim design
The ultraslim profile of the OtterBox React Series case not only enhances the aesthetic appeal of your cell phone but also makes it easy to carry around without adding bulk. -
Enhanced protection
Featuring raised edges, this protective cover is designed to safeguard your cell phone's screen and camera from scratches and drops, ensuring your device remains in pristine condition. -
Wireless charging compatibility
With wireless charging support, this back cover allows you to charge your cell phone without the need for removing the case, offering convenience and maintaining the phone's functionality.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Clear
- Designed For
- Samsung Galaxy S20
- Package Details
- Pro pack
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Wireless charging support, raised edges, ultra-slim
- Designed For
