OtterBox React Samsung Galaxy A53 5G - clear
Quicklinx: GVC5WS00 Mfr#: 77-87849
Device Type: Smartphone
Type: Case / Cover
Product Range: OtterBox React Series
Product Model: Samsung Galaxy A53
£10.38 ex VAT
£12.45 inc VAT
  • ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
  • HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
  • TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
  • KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
  • Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
  • EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Pro Packs optimise installation by reducing waste from retail packaging and saving time.
  • Robust protection
    Designed specifically for cell phone use, the OtterBox React Series back cover offers a protective shield against daily wear and tear, ensuring your device remains in pristine condition.
  • Sleek design
    The back cover's sleek design not only enhances the aesthetic appeal of your cell phone but also provides a comfortable grip, making it easier to hold and use your device throughout the day.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
7.98 cm x 1.15 cm x 16.45 cm
37.97 g
Clear
7.98 cm
1.15 cm
16.45 cm
37.97 g
Package Details
ProPack
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
42.974 g
Type: Case / Cover
Brand: OtterBox
