OtterBox React Samsung Galaxy A53 5G - black
Quicklinx: GVC6WS00 Mfr#: 77-87850
Device Type: Smartphone
Type: Case / Cover
Product Range: OtterBox React Series
Product Model: Samsung Galaxy A53
£10.35 ex VAT
£12.42 inc VAT
  • ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
  • HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
  • TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
  • KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
  • Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
  • EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Pro Packs optimise installation by reducing waste from retail packaging and saving time.
  • Enhanced durability
    Designed as a back cover, the OtterBox React Series offers robust protection for your cell phone. Its construction is focused on safeguarding against daily wear and tear, ensuring your device remains in pristine condition over time.
  • Optimal compatibility
    Specifically recommended for cell phone use, this protective cover seamlessly fits your device. It provides easy access to all ports and buttons, enhancing your user experience without compromising on protection.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
7.98 cm x 1.15 cm x 16.45 cm
37.97 g
7.98 cm
1.15 cm
16.45 cm
37.97 g
Package Details
ProPack
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
42.974 g
Type: Case / Cover
Brand: OtterBox
