OtterBox React Samsung Galaxy A33 5G - clear
Quicklinx: GVC3WS00 Mfr#: 77-86987
Device Type: Smartphone
Type: Case / Cover
Product Range: OtterBox React Series
Product Model: Samsung Galaxy A33 5G
£10.15 ex VAT
£12.18 inc VAT
  • ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
  • HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
  • TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
  • KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
  • Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
  • EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Pro Packs optimise installation by reducing waste from retail packaging and saving time.
  • Enhanced durability
    Designed to meet MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust protection against drops, bumps, and shocks, ensuring your cell phone withstands daily use.
  • Comprehensive protection
    With features like camera protection, drop protection, scratch protection, and screen protection, this back cover provides security for your device from all angles.
  • Sleek design
    The one-piece design combines with ultraslim construction and soft touch edges to offer a protective cover that doesn't add bulk, ensuring your cell phone remains comfortable to hold and easy to use.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
7.9 cm x 1.15 cm x 16.47 cm
37.65 g
Clear
7 years warranty
7.9 cm
1.15 cm
16.47 cm
37.65 g
Package Details
ProPack
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop+ protection, scratch protection, camera protection, screen protection
Cover Type
Back cover
Ultra-thin, one-piece design, soft touch edges, raised edges
MIL-STD-810G 516.6
Limited warranty - 7 years
Type: Case / Cover
Brand: OtterBox
