- ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
- HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
- TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
- KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
- Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
- EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Pro Packs optimise installation by reducing waste from retail packaging and saving time.
Enhanced protection
Designed specifically for cell phone use, the OtterBox React Series back cover offers robust protection against daily wear and tear, ensuring your device remains in pristine condition. -
Sleek design
The back cover's sleek design not only enhances the aesthetic appeal of your cell phone but also provides a comfortable grip, making it easier to hold and use your device throughout the day.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.14 cm x 1.17 cm x 17.02 cm
- 35.34 g
- Clear
- 8.14 cm
- 1.17 cm
- 17.02 cm
- 35.34 g
- Package Details
- ProPack
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Shipping Dimensions (WxDxH) / Weight
- 40.33 g
