OtterBox React Samsung Galaxy A03s - black
Quicklinx: GVCKWS00 Mfr#: 77-86768
  • ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
  • HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
  • TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
  • KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
  • Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
  • EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
Pro Packs optimise installation by reducing waste from retail packaging and saving time.
  • Enhanced durability
    Crafted from polycarbonate and thermoplastic elastomer (TPE), this hard case with a soft grip is designed to withstand the rigors of daily use, ensuring your cell phone remains protected.
  • Advanced protection
    Featuring DROP+ technology and raised edges, the OtterBox React Series offers superior drop protection up to 1.22 m, safeguarding your device from accidental falls and bumps.
  • Slim and functional
    The ultraslim design of this protective cover not only preserves the sleek profile of your cell phone but also supports wireless charging, allowing for effortless power-ups without removing the case.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
Material
Thermoplastic elastomer (TPE), polycarbonate
7 years warranty
Samsung Galaxy A03s
Package Details
Pro pack
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop+ protection
Cover Type
Back cover
DROP+ technology, raised edges, wireless charging support, ultra-slim
Max Height of Drop Protection
1.22 m
7 years
Samsung Galaxy A03s
