- Protect your smartphone with ultra-slim React with MagSafe Necklace Series, the iPhone 15 Pro case that's easy to install, while the necklace feature delivers reliable and elegant carrying options and helps to prevent drops.
- The case comes with a detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
- When the nylon rope is not in use you can rely on OtterBox trusted drop protection as React with MagSafe Necklace is tested to military standard (MIL-STD-810G 516.6).
- The React Necklace case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- Made from 50% recycled plastic, OtterBox React Necklace Series provides flawless, sleek and stylish protection from scratches and cracks.
The product is delivered without retail packaging to reduce environmental impacts by curtailing packaging waste.
Eco-friendly design
Crafted with a commitment to the environment, this case boasts a 50% recycled plastic construction, making it a choice that benefits both your phone and the planet. -
Advanced protection
Engineered to meet MIL-STD-810G 516.6 standards, this protective cover offers robust drop and fumble protection, ensuring your cell phone withstands the rigors of daily use. -
Wireless convenience
Designed with modern needs in mind, this case supports wireless charging, allowing you to power up your device without removing the case. -
Sleek and functional
Featuring a one-piece design with soft touch edges and an ultra-thin profile, this case provides a comfortable grip while maintaining the phone's slim look. -
MagSafe compatible
This case is fully compatible with MagSafe accessories, offering a seamless experience with your MagSafe charger and other accessories.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 7.56 cm x 1.11 cm x 15.16 cm
- 28.16 g
- Finish
- Soft touch
- Stardust
- Product Recycled Content
- 50 % - made of recycled plastic
- 7 years warranty
- Designed For
- Apple iPhone 15 Pro
- 7.56 cm
- 1.11 cm
- 15.16 cm
- 28.16 g
- Package Details
- Pro pack
- Finish
- Soft touch
- Stardust
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, fumble protection
- Cover Type
- Back cover
- Carrying Strap
- Necklace
- Ultra-thin, wireless charging support, one-piece design, soft touch edges
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - 7 years
- Designed For
