OtterBox React Necklace MagSafe iPhone 15 Pro Stardust - Clear
Quicklinx: HFMJWS00 Mfr#: 77-93578
Product Range: OtterBox React Series
£17.58 ex VAT
£21.09 inc VAT
  • Protect your smartphone with ultra-slim React with MagSafe Necklace Series, the iPhone 15 Pro case that's easy to install, while the necklace feature delivers reliable and elegant carrying options and helps to prevent drops.
  • The case comes with a detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
  • When the nylon rope is not in use you can rely on OtterBox trusted drop protection as React with MagSafe Necklace is tested to military standard (MIL-STD-810G 516.6).
  • The React Necklace case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
  • Made from 50% recycled plastic, OtterBox React Necklace Series provides flawless, sleek and stylish protection from scratches and cracks.
The product is delivered without retail packaging to reduce environmental impacts by curtailing packaging waste.
  • Eco-friendly design
    Crafted with a commitment to the environment, this case boasts a 50% recycled plastic construction, making it a choice that benefits both your phone and the planet.
  • Advanced protection
    Engineered to meet MIL-STD-810G 516.6 standards, this protective cover offers robust drop and fumble protection, ensuring your cell phone withstands the rigors of daily use.
  • Wireless convenience
    Designed with modern needs in mind, this case supports wireless charging, allowing you to power up your device without removing the case.
  • Sleek and functional
    Featuring a one-piece design with soft touch edges and an ultra-thin profile, this case provides a comfortable grip while maintaining the phone's slim look.
  • MagSafe compatible
    This case is fully compatible with MagSafe accessories, offering a seamless experience with your MagSafe charger and other accessories.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
7.56 cm x 1.11 cm x 15.16 cm
28.16 g
Finish
Soft touch
Stardust
Product Recycled Content
50 % - made of recycled plastic
7 years warranty
Apple iPhone 15 Pro
7.56 cm
1.11 cm
15.16 cm
28.16 g
Package Details
Pro pack
Finish
Soft touch
Stardust
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop+ protection, fumble protection
Cover Type
Back cover
Carrying Strap
Necklace
Ultra-thin, wireless charging support, one-piece design, soft touch edges
MagSafe Compatibility
MIL-STD-810G 516.6
Limited warranty - 7 years
Apple iPhone 15 Pro
Brand: OtterBox
