- Protect your smartphone with ultra-slim React with MagSafe Necklace Series, the iPhone 15 Pro Max case that's easy to install, while the necklace feature delivers reliable and elegant carrying options and helps to prevent drops.
- The case comes with a detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
- When the nylon rope is not in use you can rely on OtterBox trusted drop protection as React with MagSafe Necklace is tested to military standard (MIL-STD-810G 516.6).
- The React Necklace case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- Made from 50% recycled plastic, OtterBox React Necklace Series provides flawless, sleek and stylish protection from scratches and cracks.
Enhanced durability
Featuring DROP+ technology, the OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains safe in demanding situations. -
Designed with MagSafe compatibility, this case allows for seamless use of MagSafe accessories, offering a convenient and efficient charging experience without the need to remove the case. -
Shock-resistant protection
The shock-resistant feature of this protective cover absorbs and disperses the force of impact, providing peace of mind that your device is safeguarded from unexpected bumps and drops.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- Clear
- Designed For
- Apple iPhone 15 Pro Max
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Shock-resistant
- Cover Type
- Back cover
- Carrying Strap
- Rope
- DROP+ technology
- MagSafe Compatibility
- Designed For
