OtterBox React Necklace MagSafe iPhone 15 Pro Max - Clear
Quicklinx: HFN7WS00 Mfr#: 77-93585
  • Protect your smartphone with ultra-slim React with MagSafe Necklace Series, the iPhone 15 Pro Max case that's easy to install, while the necklace feature delivers reliable and elegant carrying options and helps to prevent drops.
  • The case comes with a detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
  • When the nylon rope is not in use you can rely on OtterBox trusted drop protection as React with MagSafe Necklace is tested to military standard (MIL-STD-810G 516.6).
  • The React Necklace case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
  • Made from 50% recycled plastic, OtterBox React Necklace Series provides flawless, sleek and stylish protection from scratches and cracks.
  • Enhanced durability
    Featuring DROP+ technology, the OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains safe in demanding situations.
  • MagSafe compatibility
    Designed with MagSafe compatibility, this case allows for seamless use of MagSafe accessories, offering a convenient and efficient charging experience without the need to remove the case.
  • Shock-resistant protection
    The shock-resistant feature of this protective cover absorbs and disperses the force of impact, providing peace of mind that your device is safeguarded from unexpected bumps and drops.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Clear
Apple iPhone 15 Pro Max
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Shock-resistant
Cover Type
Back cover
Carrying Strap
Rope
DROP+ technology
MagSafe Compatibility
