- Protect your smartphone with ultra-slim React with MagSafe Necklace Series, the iPhone 15 Pro case that's easy to install, while the necklace feature delivers reliable and elegant carrying options and helps to prevent drops.
- The case comes with a detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
- When the nylon rope is not in use you can rely on OtterBox trusted drop protection as React with MagSafe Necklace is tested to military standard (MIL-STD-810G 516.6).
- The React Necklace case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- Made from 50% recycled plastic, OtterBox React Necklace Series provides flawless, sleek and stylish protection from scratches and cracks.
The product is delivered without retail packaging to reduce environmental impacts by curtailing packaging waste. This helps us move closer to a more sustainable future.
Enhanced protection
Equipped with DROP+ technology, the OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains in pristine condition. -
MagSafe compatible
Designed with convenience in mind, this protective cover fully supports MagSafe accessories, allowing for seamless integration with your device's ecosystem.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- Clear
- Designed For
- Apple iPhone 15 Pro
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Carrying Strap
- Rope
- DROP+ technology
- MagSafe Compatibility
- Designed For
