OtterBox React Necklace MagSafe iPhone 15 Pro - Clear
Quicklinx: HFMHWS00 Mfr#: 77-93574
Product Range: OtterBox React Series
£18.21 ex VAT
£21.85 inc VAT
  • Protect your smartphone with ultra-slim React with MagSafe Necklace Series, the iPhone 15 Pro case that's easy to install, while the necklace feature delivers reliable and elegant carrying options and helps to prevent drops.
  • The case comes with a detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
  • When the nylon rope is not in use you can rely on OtterBox trusted drop protection as React with MagSafe Necklace is tested to military standard (MIL-STD-810G 516.6).
  • The React Necklace case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
  • Made from 50% recycled plastic, OtterBox React Necklace Series provides flawless, sleek and stylish protection from scratches and cracks.
The product is delivered without retail packaging to reduce environmental impacts by curtailing packaging waste. This helps us move closer to a more sustainable future.
  • Enhanced protection
    Equipped with DROP+ technology, the OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains in pristine condition.
  • MagSafe compatible
    Designed with convenience in mind, this protective cover fully supports MagSafe accessories, allowing for seamless integration with your device's ecosystem.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Clear
Apple iPhone 15 Pro
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Carrying Strap
Rope
DROP+ technology
MagSafe Compatibility
Apple iPhone 15 Pro
Brand: OtterBox
