Ultra-thin, resilient necklace phone case protects against drops and fumbles. This slim case is thoughtfully designed to provide seamless interaction with MagSafe chargers and accessories. Its solid one-piece form is precision-fit to your phone and its soft touch edges provide great grip. The case installs easily, while the necklace feature delivers reliable carrying options and helps to prevent drops. Wrap your phone in the trusted and stylish protection of React Series Necklace MagSafe Case.
- Ultra-thin case
- Necklace feature provides drop prevention
- Hands-free carrying and tethering
- Seamless interaction with MagSafe chargers and accessories
- Case is made with more than 50% recycled plastic
- Easy on and off
- Wireless charging compatible
- DROP+ | case is drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
- Detachable nylon rope with size adjustment to wear your phone as a necklace or crossbody
Innovative protection
The OtterBox React Series case offers exceptional drop+ protection and fumble protection, meeting the rigorous MIL-STD-810G 516.6 standards. This ensures your cell phone withstands the bumps and drops of daily use. -
Eco-friendly design
Crafted with a commitment to sustainability, this protective cover is made of 50% recycled plastic, reducing environmental impact without compromising on protection or style. -
Seamless functionality
Designed for convenience, the case supports wireless charging and is compatible with MagSafe, allowing for effortless charging. Its ultraslim, one-piece design with soft touch edges ensures a comfortable grip while maintaining 5G compatibility.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.28 cm x 1.07 cm x 16.59 cm
- 32.3 g
- Stardust
- Product Recycled Content
- 50 % - made of recycled plastic
- 7 years warranty
- Designed For
- Apple iPhone 14 Plus, 15 Plus
- 8.28 cm
- 1.07 cm
- 16.59 cm
- 32.3 g
- Package Details
- Pro pack
- Stardust
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, fumble protection
- Cover Type
- Back cover
- Carrying Strap
- Necklace
- Ultra-thin, wireless charging support, one-piece design, 5G compatibility, soft touch edges
- Cover Features
- Built-in magnets
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - 7 years
- Designed For
