Ultra-thin and resilient, React Series Necklace for MagSafe is the phone necklace that protects your phone from drops and lets you carry it hands free using the built-in necklace. Its solid, one-piece form is precision-fit for your phone and its soft-touch edges provide a sure grip. Built-in magnets let you snap to MagSafe accessories, opening new ways to use your smartphone. Plus, the case installs fast, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series Necklace for MagSafe.
Reliable drop protection
Designed to meet MIL-STD-810G 516.6 standards, this case provides robust drop+ protection, safeguarding devices against accidental falls and impacts. -
Eco-friendly materials
Constructed from 35% recycled plastic, this case reflects a commitment to sustainability, allowing users to protect their phones while being mindful of the environment. -
Seamless wireless charging
The case supports wireless charging, making it easy to charge devices without removing the cover, ensuring convenience and saving time. -
User-friendly design
Featuring a one-piece design with soft touch edges, the case is easy to apply and remove while providing a comfortable grip for everyday use. -
MagSafe compatibility
The case is compatible with MagSafe accessories, allowing users to easily attach and detach compatible items for enhanced usability.
