Ultra-thin and resilient, React Series Necklace for MagSafe is the phone necklace that protects your phone from drops and lets you carry it hands free using the built-in necklace. Its solid, one-piece form is precision-fit for your phone and its soft-touch edges provide a sure grip. Built-in magnets let you snap to MagSafe accessories, opening new ways to use your smartphone. Plus, the case installs fast, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series Necklace for MagSafe.
Durable drop+ protection
This protective cover is designed to withstand the rigors of daily use, featuring a rugged construction that meets military standards for drop protection. -
Eco-friendly materials
Made from 35% recycled plastic, this case reflects a commitment to sustainability while still providing the durability needed to protect your device. -
Convenient wireless charging
With support for wireless charging and MagSafe compatibility, this case allows for effortless recharging without removing the cover. -
Sleek one-piece design
The one-piece design offers a seamless look while ensuring easy installation and removal of the case, allowing users to switch out cases as desired. -
Comfortable soft touch edges
Soft touch edges enhance grip and comfort, making it easy to hold your phone securely without slipping.
