Ultra-thin and resilient, React Series Necklace for MagSafe is the phone necklace that protects your phone from drops and lets you carry it hands free using the built-in necklace. Its solid, one-piece form is precision-fit for your phone and its soft-touch edges provide a sure grip. Built-in magnets let you snap to MagSafe accessories, opening new ways to use your smartphone. Plus, the case installs fast, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series Necklace for MagSafe.
Durable protection
This protective cover provides bump and drop protection, adhering to the stringent MIL-STD-810G 516.6 standards for safeguarding your device in various environments. -
Sustainable materials
Constructed from 35% recycled plastic, this case offers an eco-friendly option while maintaining durability and quality, supporting efforts toward reducing plastic waste. -
Streamlined design
The ultra-thin, one-piece design of the React Necklace ensures easy handling and a sleek profile, preserving the phone's aesthetics while providing essential protection. -
Wireless charging compatible
With integrated wireless charging support, the case allows hassle-free charging without the need to remove your phone from the protective cover. -
Enhanced grip
Soft touch edges provide comfort and improved handling, helping to prevent accidental drops during everyday use.
- OtterBox React Necklace - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.258 cm x 1.11 cm x 17.703 cm
- 96.87 g
- Black
- Product Recycled Content
- 35 % - made of recycled plastic
- 7 years warranty
- Designed For
- Apple iPhone 16 Pro Max
- 8.258 cm
- 1.11 cm
- 17.703 cm
- 96.87 g
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, bump protection
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - 7 years
- Designed For
