OtterBox React Necklace MagSafe (lanyard) iPhone 15 Pro Max - Black
Quicklinx: HFN6WS00 Mfr#: 77-93588
Product Range: OtterBox React Series
£17.58 ex VAT
£21.09 inc VAT
  • Protect your smartphone with ultra-slim React with MagSafe Lanyard Series, the iPhone 15 Pro Max case that's easy to install, while the lanyard feature delivers reliable carrying options and helps to prevent drops.
  • The case comes with a detachable nylon lanyard with carabiners and size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
  • When the nylon lanyard is not in use you can rely on OtterBox trusted drop protection as React Lanyard is tested to military standard (MIL-STD-810G 516.6).
  • The React with MagSafe Lanyard case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
  • Made from 50% recycled plastic, OtterBox React Lanyard Series provides flawless, sleek and stylish protection from scratches and cracks.
  • Enhanced protection
    Equipped with DROP+ technology, the OtterBox React Series case offers robust shock-resistant protection, ensuring your cell phone withstands the rigors of daily use.
  • Convenient portability
    Featuring a detachable lanyard, this protective cover allows for easy and secure carrying, making it perfect for on-the-go use.
  • MagSafe compatibility
    Designed with MagSafe compatibility, this back cover ensures you can charge your device effortlessly without removing the case, providing both protection and convenience.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Apple iPhone 15 Pro Max
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Shock-resistant
Cover Type
Back cover
Carrying Strap
Detachable lanyard
DROP+ technology
MagSafe Compatibility
Brand: OtterBox
