- Protect your smartphone with ultra-slim React with MagSafe Lanyard Series, the iPhone 15 Plus / iPhone 14 Plus case that's easy to install, while the lanyard feature delivers reliable carrying options and helps to prevent drops.
- The case comes with a detachable nylon lanyard with carabiners and size adjustment to wear your phone as a necklace or crossbody for hands-free carrying and tethering.
- When the nylon lanyard is not in use you can rely on OtterBox trusted drop protection as React Lanyard is tested to military standard (MIL-STD-810G 516.6).
- The React with MagSafe Lanyard case guarantees MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- Made from 50% recycled plastic, OtterBox React Lanyard Series provides flawless, sleek and stylish protection from scratches and cracks.
- Pair your case with a scratch resistant and durable OtterBox screen protector for total, 360-degree protection.
- Compatible with iPhone 15 Plus / iPhone 14 Plus
Enhanced protection
Equipped with DROP+ technology, the OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains in pristine condition. -
MagSafe compatible
Designed with convenience in mind, this back cover is fully compatible with MagSafe accessories, allowing for easy attachment and faster wireless charging without sacrificing safety.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- Black
- Designed For
- Apple iPhone 15 Plus
- Package Details
- Pro pack
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- DROP+ technology
- MagSafe Compatibility
- Designed For
