Ultra-thin, trendy iPhone 15 Pro Max case protects against drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
- DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
- Ultra-thin case
- Wireless charging compatible
- Made with more than 50% recycled plastic
Eco-friendly choice
With a commitment to sustainability, this case is made of 50% recycled plastic, offering an eco-friendly option for environmentally conscious consumers. -
Robust protection
Engineered to meet MIL-STD-810G 516.6 standards, this case provides superior drop and scrape protection, ensuring your cell phone withstands the rigors of daily use. -
Sleek design
Featuring a one-piece design with soft touch edges and an ultraslim profile, this case combines style with functionality, allowing for wireless charging without sacrificing protection.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.17 cm x 1.11 cm x 16.48 cm
- 31.83 g
- Material
- Polycarbonate, synthetic rubber
- Stardust
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 15 Pro Max
- 8.17 cm
- 1.11 cm
- 16.48 cm
- 31.83 g
- Package Details
- Pro pack
- Material
- Stardust
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, scrape protection
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges
- MIL-STD-810G 516.6
- Designed For
