Ultra-thin, trendy iPhone 15 Pro Max case protects against drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
- DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
- Ultra-thin case
- Wireless charging compatible
- Made with more than 50% recycled plastic
Eco-friendly design
Crafted with a commitment to the environment, this case boasts a 50% recycled content, making a statement not just in style but in sustainability. The use of recycled plastic in its construction speaks volumes about the brand's dedication to reducing environmental impact. -
Robust protection
Engineered to withstand the unexpected, this protective cover meets the rigorous MIL-STD-810G 516.6 standard, offering drop and scrape protection. Its polycarbonate and synthetic rubber materials ensure your cell phone remains unscathed from daily mishaps. -
Sleek functionality
Featuring an ultraslim, one-piece design with soft touch edges, this case does not compromise on protection or style. Its thoughtful design supports wireless charging, ensuring your device stays powered without removing the case.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.17 cm x 1.11 cm x 16.48 cm
- 31.83 g
- Material
- Polycarbonate, synthetic rubber
- Peach perfect (peach)
- Product Recycled Content
- 50 % - made of recycled plastic
- 7 years warranty
- Designed For
- Apple iPhone 15 Pro Max
- 8.17 cm
- 1.11 cm
- 16.48 cm
- 31.83 g
- Package Details
- Pro pack
- Material
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, scrape protection
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges
- MIL-STD-810G 516.6
- 7 years
- Designed For
