Ultra-thin, trendy iPhone 15 Pro Max case protects against drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
- DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
- Ultra-thin case
- Wireless charging compatible
- Made with more than 50% recycled plastic
Enhanced durability
Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop and scrape protection, ensuring your cell phone withstands the rigors of daily use. -
Eco-friendly choice
With 50% of its composition made from recycled plastic, this case not only protects your phone but also contributes to a more sustainable environment. -
Sleek design
The one-piece design, combined with soft touch edges and an ultra-thin profile, provides a perfect blend of protection without adding bulk, maintaining the sleek aesthetics of your device. -
Wireless convenience
Designed to support wireless charging, this case allows you to charge your device without the need to remove it, offering convenience and maintaining the case's protective integrity.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.17 cm x 1.11 cm x 16.49 cm
- Material
- Polycarbonate, thermoplastic elastomer (TPE)
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 15 Pro Max
- 8.17 cm
- 1.11 cm
- 16.49 cm
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection, scrape protection
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
- MIL-STD-810G 516.6
- Designed For
