OtterBox React iPhone 15 Pro Max - Clear
Quicklinx: HFN2WS00 Mfr#: 77-92778
Product Range: OtterBox React Series
£7.88 ex VAT
£9.45 inc VAT
Ultra-thin, trendy iPhone 15 Pro Max case protects against drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
  • DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
  • Hard case with soft grip edges
  • Ultra-thin case
  • Wireless charging compatible
  • Made with more than 50% recycled plastic
  • Enhanced durability
    Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop and scrape protection, ensuring your cell phone withstands the rigors of daily use.
  • Eco-friendly choice
    With 50% of its composition made from recycled plastic, this case not only protects your phone but also contributes to a more sustainable environment.
  • Sleek design
    The one-piece design, combined with soft touch edges and an ultra-thin profile, provides a perfect blend of protection without adding bulk, maintaining the sleek aesthetics of your device.
  • Wireless convenience
    Designed to support wireless charging, this case allows you to charge your device without the need to remove it, offering convenience and maintaining the case's protective integrity.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
8.17 cm x 1.11 cm x 16.49 cm
Material
Polycarbonate, thermoplastic elastomer (TPE)
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15 Pro Max
8.17 cm
1.11 cm
16.49 cm
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection, scrape protection
Cover Type
Back cover
Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
MIL-STD-810G 516.6
Brand: OtterBox
