OtterBox React iPhone 15 Pro - Clear
Quicklinx: HFM9WS00 Mfr#: 77-92748
Device Type: Apple iPhone 15
Type: Case
Product Range: OtterBox React Series
Product Model: [N/A]
£6.45 ex VAT
£7.74 inc VAT
Ultra-thin, trendy iPhone 15 Pro case protects against drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
  • DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
  • Hard case with soft grip edges
  • Ultra-thin case
  • Wireless charging compatible
  • Made with more than 50% recycled plastic
  • Enhanced durability
    Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop and scrape protection, ensuring your cell phone withstands daily use.
  • Eco-friendly choice
    With 50% of its composition made from recycled plastic, this protective cover not only safeguards your device but also contributes to a more sustainable environment.
  • Sleek design
    The one-piece design, combined with soft touch edges and an ultraslim profile, provides a comfortable grip without adding bulk, maintaining the sleek aesthetics of your cell phone.
  • Wireless charging compatibility
    Designed to support wireless charging, this case allows you to charge your device without the need to remove the cover, offering convenience and maintaining the case's protective integrity.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
7.56 cm x 1.11 cm x 15.16 cm
Material
Polycarbonate, thermoplastic elastomer (TPE)
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15 Pro
7.56 cm
1.11 cm
15.16 cm
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection, scrape protection
Cover Type
Back cover
Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
MIL-STD-810G 516.6
Apple iPhone 15 Pro
Type: Case
Brand: OtterBox
