- The Sleek Protective iPhone 15 Plus / iPhone 14 Plus case undergoes thousands of hours of drop testing to ensure your smartphone gets the utmost protection.
- Protect your smartphone with ultra-slim Sleek Series, the iPhone 15 Plus / iPhone 14 Plus case that's easy to install and has as many drops as military standard ( MIL-STD-810G 516.6 ).
- Made from 50% recycled plastic, OtterBox Sleek Protective Case Series provides flawless, sleek and stylish protection from scratches and cracks.
- This ultra-slim, pocket-friendly case has raised screen bumpers to help protect the touchscreen.
- Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip. It also works with Appleās MagSafe charger and Qi Wireless charging.
- Pair with an OtterBox screen protector for total, 360-degree protection
- Compatible with iPhone 15 Plus / iPhone 14 Plus
Enhanced durability
Equipped with DROP+ technology and meeting MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust protection against drops, bumps, and shocks, ensuring your cell phone withstands the rigors of daily use. -
Eco-friendly choice
With 50% of its composition made from recycled plastic, this case not only protects your device but also contributes to a healthier planet by reducing waste and promoting the use of recycled materials. -
Sleek design
The ultraslim profile combined with soft edges provides a comfortable grip without adding bulk, maintaining the sleek aesthetics of your cell phone while ensuring easy access to all ports and buttons. -
Wireless convenience
Designed to support wireless charging, this case allows you to charge your device without the need to remove it, offering a seamless charging experience that keeps you connected on-the-go. -
Antimicrobial protection
This case features antimicrobial protection that helps inhibit the growth of bacteria on the case, ensuring a cleaner surface and providing an added layer of hygiene to your daily device use.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.364 cm x 1.066 cm x 16.588 cm
- Material
- Polycarbonate, thermoplastic elastomer (TPE)
- Black crystal
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 15 Plus
- 8.364 cm
- 1.066 cm
- 16.588 cm
- Package Details
- Pro pack
- Material
- Black crystal
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Antimicrobial, shock-resistant
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, soft edges, DROP+ technology
- MIL-STD-810G 516.6
- Designed For
