OtterBox React iPhone 15 Plus/14 Plus - Clear/Black
Quicklinx: HFL8WS00 Mfr#: 77-92767
Product Range: OtterBox React Series
£10.08 ex VAT
£12.09 inc VAT
  • The Sleek Protective iPhone 15 Plus / iPhone 14 Plus case undergoes thousands of hours of drop testing to ensure your smartphone gets the utmost protection.
  • Protect your smartphone with ultra-slim Sleek Series, the iPhone 15 Plus / iPhone 14 Plus case that's easy to install and has as many drops as military standard ( MIL-STD-810G 516.6 ).
  • Made from 50% recycled plastic, OtterBox Sleek Protective Case Series provides flawless, sleek and stylish protection from scratches and cracks.
  • This ultra-slim, pocket-friendly case has raised screen bumpers to help protect the touchscreen.
  • Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip. It also works with Apple’s MagSafe charger and Qi Wireless charging.
  • Pair with an OtterBox screen protector for total, 360-degree protection
  • Compatible with iPhone 15 Plus / iPhone 14 Plus
  • Enhanced durability
    Equipped with DROP+ technology and meeting MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust protection against drops, bumps, and shocks, ensuring your cell phone withstands the rigors of daily use.
  • Eco-friendly choice
    With 50% of its composition made from recycled plastic, this case not only protects your device but also contributes to a healthier planet by reducing waste and promoting the use of recycled materials.
  • Sleek design
    The ultraslim profile combined with soft edges provides a comfortable grip without adding bulk, maintaining the sleek aesthetics of your cell phone while ensuring easy access to all ports and buttons.
  • Wireless convenience
    Designed to support wireless charging, this case allows you to charge your device without the need to remove it, offering a seamless charging experience that keeps you connected on-the-go.
  • Antimicrobial protection
    This case features antimicrobial protection that helps inhibit the growth of bacteria on the case, ensuring a cleaner surface and providing an added layer of hygiene to your daily device use.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
8.364 cm x 1.066 cm x 16.588 cm
Material
Polycarbonate, thermoplastic elastomer (TPE)
Black crystal
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15 Plus
8.364 cm
1.066 cm
16.588 cm
Package Details
Pro pack
Material
Black crystal
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Antimicrobial, shock-resistant
Cover Type
Back cover
Ultra-thin, wireless charging support, soft edges, DROP+ technology
MIL-STD-810G 516.6
Brand: OtterBox
