Ultra-thin, trendy iPhone 15 case protects against drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
- DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
- Ultra-thin case
- Wireless charging compatible
- Made with more than 50% recycled plastic
Enhanced protection
Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains safe in the most demanding conditions. -
Sleek design
The one-piece design of this case, combined with ultra-thin construction and soft touch edges, provides a sleek, comfortable grip without adding bulk to your device. Its aesthetic appeal complements your cell phone's design while offering easy access to all ports and buttons. -
Eco-friendly choice
With 50% of the case made from recycled plastic, choosing the OtterBox React Series case is a step towards reducing environmental impact. This eco-conscious design does not compromise on protection or style, making it an ideal choice for the environmentally aware consumer.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.562 cm x 1.065 cm x 15.17 cm
- Material
- Polycarbonate, thermoplastic elastomer (TPE)
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 13, 14, 15
- 7.562 cm
- 1.065 cm
- 15.17 cm
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
- MIL-STD-810G 516.6
- Designed For
