- ULTRA-SLIM, POCKET FRIENDLY: Ultra-slim, one-piece design case slips easily in and out of pockets
- HARD CASE WITH SOFT GRIP: Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip
- TESTED BY OTTERBOX. BUILT FOR YOU: OtterBox Certified Drop+ Protection means 24+ tests over 238+ hours, which certify that this slim, low-profile case performs when it matters most
- KEEPS SCREEN SAFE: Raised screen bumpers help protect touchscreen
- Qi WIRELESS CHARGING COMPATIBLE: Qi Wireless Charging works with case
- EASY TO CLEAN: Our cases are simple to clean with water and soap, as well as easy to disinfect
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Clear
- Designed For
- Apple iPhone 12, 12 Pro
- Package Details
- Pro pack
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Wireless Charging Standards
- Qi
- Cover Type
- Back cover
- Designed For
