React Series is the ultra-slim, resilient OtterBox case that protects your phone from drops and scrapes. Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip. The case installs easily onto your phone and it slides in and out of pockets seamlessly. OtterBox is known for its stellar customer support and industry-leading warranty. Wrap your phone in the trusted protection of React Series.
Enhanced durability
Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this protective cover offers exceptional drop protection, ensuring your cell phone withstands the rigors of daily use. -
Eco-friendly choice
Made of 50% recycled plastic, this case not only protects your phone but also the planet, making it an ideal choice for environmentally conscious consumers. -
Advanced protection
Featuring antimicrobial protection and designed to prevent scrapes, this case keeps your cell phone clean and safe from everyday damages. -
Wireless convenience
With its one-piece design supporting wireless charging, this case allows for effortless charging without the need to remove it, blending protection with convenience.
- OtterBox React Series ProPack Packaging - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.26 cm x 1.37 cm x 16.57 cm
- Material
- Polycarbonate, TPE
- Black crystal
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Pro Max
- 8.26 cm
- 1.37 cm
- 16.57 cm
- Material
- Black crystal
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Antimicrobial, drop protection, scrape protection
- Cover Type
- Back cover
- Wireless charging support, DROP+ technology, one-piece design
- Cover Features
- Soft-touch
- MIL-STD-810G 516.6
- Lifetime
- Designed For
