Ultra-thin, resilient trendy iPhone case protects your phone from drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case installs easily and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of react series.
Eco-friendly design
Crafted from 50% recycled plastic, this OtterBox React Series case combines sustainability with protection. Its use of polycarbonate and thermoplastic elastomer (TPE) ensures a durable shield against daily wear and tear. -
Advanced protection
Designed to meet MIL-STD-810G 516.6 standards, this case offers antimicrobial protection and drop protection, safeguarding your cell phone from scratches, drops, and the buildup of microbes. -
Wireless charging compatible
The ultra-thin, one-piece design supports wireless charging, allowing you to power up your device without removing the case. Enjoy the convenience of charging with no strings attached.
- OtterBox React Series ProPack Packaging - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.31 cm x 1.29 cm x 16.59 cm
- Material
- Polycarbonate, thermoplastic elastomer (TPE), 50% recycled plastic
- Purplexing
- 7 years warranty
- Designed For
- Apple iPhone 14 Plus
- 8.31 cm
- 1.29 cm
- 16.59 cm
- Package Details
- Polybag
- Material
- Purplexing
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, antimicrobial, drop+ protection
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design
- Cover Features
- Soft-touch
- MIL-STD-810G 516.6
- 7 years
- Designed For
