Ultra-thin, resilient React Series case protects your phone from drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case is easily installed, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
- Ultra-thin case
- Engineered to stay clear
- Made with more than 50% recycled plastic
- Easy on and off
- Wireless charging compatible
- DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
- Hard case with soft grip edges
Enhanced durability
Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust protection against drops and impacts, ensuring your cell phone remains in pristine condition. -
Sleek design
The one-piece design coupled with soft touch edges and an ultra-thin profile not only adds minimal bulk to your device but also provides a comfortable grip, making it easier to hold your phone throughout the day. -
Eco-friendly choice
With 50% of the case made from recycled plastic, choosing this OtterBox React Series case is a step towards reducing environmental impact without compromising on quality or protection.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.56 cm x 1.11 cm x 15.16 cm
- 27.42 g
- Material
- Polycarbonate, synthetic rubber
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 15 Pro
- 7.56 cm
- 1.11 cm
- 15.16 cm
- 27.42 g
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
- MIL-STD-810G 516.6
- Designed For
