OtterBox React Case Apple iPhone 15 - Clear
Quicklinx: HG8NWS00 Mfr#: 77-92805
Device Type: Apple iPhone 15
Type: Case
Product Range: OtterBox React Series
Product Model: Apple iPhone 15
Hurry, only 3 left in stock!
£10.05 ex VAT
£12.06 inc VAT
Ultra-thin, resilient React Series case protects your phone from drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case is easily installed, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series.
  • Ultra-thin case
  • Engineered to stay clear
  • Made with more than 50% recycled plastic
  • Easy on and off
  • Wireless charging compatible
  • DROP+ | drop tested to meet military standard (MIL-STD-810G 516.6)
  • Hard case with soft grip edges
  • Enhanced durability
    Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop and scrape protection, ensuring your cell phone withstands the rigors of daily use.
  • Sleek design
    The one-piece design of this case, combined with soft touch edges and an ultra-slim profile, provides a sleek look without compromising on protection. Its design not only enhances the aesthetic appeal of your device but also ensures ease of use.
  • Eco-friendly choice
    With 50% of the case made from recycled plastic, choosing this OtterBox React Series case is a step towards reducing your environmental footprint. Its commitment to sustainability is matched by its performance and durability.
  • Wireless charging compatibility
    This case supports wireless charging, allowing you to charge your cell phone without removing the case. The combination of protection and convenience makes it an ideal choice for the modern smartphone user.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
7.652 cm x 1.065 cm x 15.17 cm
27.32 g
Material
Polycarbonate, synthetic rubber
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15
7.652 cm
1.065 cm
15.17 cm
27.32 g
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection, scrape protection
Cover Type
Back cover
Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
MIL-STD-810G 516.6
Apple iPhone 15
Type: Case
Brand: OtterBox
