OtterBox React Apple iPhone 13 Pro - clear
Quicklinx: GVFKWS00 Mfr#: 77-85870
Device Type: Apple
Type: Case / Cover
Product Range: OtterBox
Product Model: Apple iPhone 13 Pro
Hurry, only 3 left in stock!
£10.25 ex VAT
£12.30 inc VAT
React Series is an ultra-slim, resilient OtterBox case that protects your phone from drops and scrapes. Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip. The case installs easily onto your phone and it slides in and out of pockets seamlessly. OtterBox is known for its stellar customer support and industry-leading warranty. Wrap your phone in the trusted protection of React Series.
  • Enhanced durability
    Equipped with DROP+ technology and compliant with MIL-STD 810G 516.6, this OtterBox React Series case offers robust drop protection, ensuring your cell phone withstands the bumps and drops of daily use.
  • Ergonomic design
    The hard case features a soft grip that not only enhances comfort during use but also provides additional security by reducing the likelihood of accidental slips and falls.
  • Comprehensive protection
    Designed with raised edges, this protective cover safeguards your cell phone's screen and camera, minimizing the risk of scratches and damage when placed face down on surfaces.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
Clear
7 years warranty
Apple iPhone 13 Pro
Package Details
Pro pack
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection
Cover Type
Back cover
Raised edges, DROP+ technology
MIL-STD 810G 516.6
7 years
Apple iPhone 13 Pro
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GVFK 051392
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £7.58
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: Apple
Type: Case / Cover
Brand: OtterBox
Stock Status: Used Stock
