React Series is an ultra-slim, resilient OtterBox case that protects your phone from drops and scrapes. Its solid one-piece form is precision designed for your phone and its soft touch edges provide great grip. Wrap your phone in the trusted protection of React Series.
OtterBox Trusted Glass installs easily and helps protect your screen from drops, breaks and scratches. The glass resists smudges and fingerprints while maintaining the vivid clarity of your display. You can rely on OtterBox Trusted Glass to guard your screen from random daily scrapes and tumbles.
 - OtterBox React Series - back cover for mobile phone
- Product Type
 - Back cover for mobile phone
- Bundled with
 - Trusted Glass screen protector
 - 8.11 cm x 1.22 cm x 16.91 cm
 - 35.98 g
 - Clear
- Designed For
 - Samsung Galaxy A32 5G
 - 8.11 cm
 - 1.22 cm
 - 16.91 cm
 - 35.98 g
 - Clear
Carrying Case
 - Protective cover
- Bundled with
- Recommended Use
 - For mobile phone
- Protection
 - Drop protection, scratch protection
- Cover Type
 - Back cover
- Shipping Dimensions (WxDxH) / Weight
 - 21.59 cm x 11.58 cm x 3.81 cm
 - Wireless charging support, raised edges, DROP+ technology, one-piece design, 5G compatibility, ultra-slim
- Cover Features
 - Soft-touch
 - MIL-STD-810G 516.6
- Designed For
