Enhanced durability
Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop protection, safeguarding your cell phone from accidental falls and impacts. -
Slim yet protective
The ultra-slim design of the OtterBox React Series hard case with soft grip not only adds minimal bulk to your device but also provides a comfortable grip, ensuring your cell phone stays protected without sacrificing style. -
Screen safety
Bundled with Trusted Glass screen protector, this case offers comprehensive protection for your device, covering both the back and the screen against scratches and drops. -
Wireless charging compatible
Designed with convenience in mind, this protective cover supports wireless charging, allowing you to charge your cell phone without removing the case.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Bundled with
- Trusted Glass screen protector
- 7.82 cm x 1.28 cm x 15.17 cm
- 27.2 g
- Clear
- Designed For
- Apple iPhone 13 Pro
- 7.82 cm
- 1.28 cm
- 15.17 cm
- 27.2 g
- Clear
Carrying Case
- Protective cover
- Bundled with
- Recommended Use
- For mobile phone
- Protection
- Drop protection, scratch protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, DROP+ technology, ultra-slim
- MIL-STD-810G 516.6
- Designed For
