Ultra-thin, resilient React Series case protects your phone from drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case is easily installed, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series. OtterBox Glass screen cover installs easily and helps protect your display against drops, breaks and scratches. The glass resists smudges and fingerprints while it maintains the vivid clarity of your display.
Enhanced durability
Equipped with technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop protection, ensuring your cell phone withstands the rigors of daily use. -
Sleek protection
The one-piece design, combined with ultra-thin construction and soft touch edges, provides a sleek yet protective covering for your cell phone, enhancing grip without adding bulk. -
Eco-friendly choice
With 50% of the case made from recycled plastic, choosing this OtterBox React Series case is a step towards reducing environmental impact, without compromising on protection or style. -
Wireless convenience
Designed to support wireless charging, this case allows you to charge your cell phone without the need to remove it, offering convenience and maintaining protection. -
Comprehensive protection
This case not only guards against drops but also offers fingerprint, scrape, and scratch resistance, ensuring your cell phone remains in pristine condition.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.56 cm x 1.11 cm x 15.16 cm
- 35 g
- Material
- Plastic
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 15 Pro
- 7.56 cm
- 1.11 cm
- 15.16 cm
- 35 g
- Material
- Plastic
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection, scratch protection, fingerprint-resistant, scrape protection
- Cover Type
- Back cover
- Included Accessories
- 9H tempered glass screen protector
- Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
- MIL-STD-810G 516.6
- Designed For
