OtterBox React + Glass iPhone 15 Pro - Clear
Quicklinx: HFR3WS00 Mfr#: 78-81235
£15.79 ex VAT
£18.94 inc VAT
Ultra-thin, resilient React Series case protects your phone from drops and scrapes. Its solid one-piece form is precision-fit for your phone and its soft touch edges provide great grip. The case is easily installed, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series. OtterBox Glass screen cover installs easily and helps protect your display against drops, breaks and scratches. The glass resists smudges and fingerprints while it maintains the vivid clarity of your display.
  • Enhanced durability
    Equipped with technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox React Series case offers robust drop protection, ensuring your cell phone withstands the rigors of daily use.
  • Sleek protection
    The one-piece design, combined with ultra-thin construction and soft touch edges, provides a sleek yet protective covering for your cell phone, enhancing grip without adding bulk.
  • Eco-friendly choice
    With 50% of the case made from recycled plastic, choosing this OtterBox React Series case is a step towards reducing environmental impact, without compromising on protection or style.
  • Wireless convenience
    Designed to support wireless charging, this case allows you to charge your cell phone without the need to remove it, offering convenience and maintaining protection.
  • Comprehensive protection
    This case not only guards against drops but also offers fingerprint, scrape, and scratch resistance, ensuring your cell phone remains in pristine condition.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
7.56 cm x 1.11 cm x 15.16 cm
35 g
Material
Plastic
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15 Pro
7.56 cm
1.11 cm
15.16 cm
35 g
Material
Plastic
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop protection, scratch protection, fingerprint-resistant, scrape protection
Cover Type
Back cover
9H tempered glass screen protector
Ultra-thin, wireless charging support, one-piece design, soft touch edges, DROP+ technology
MIL-STD-810G 516.6
Apple iPhone 15 Pro
