The React Series solid one-piece form is precision designed for your phone, and its soft-touch edges provide great grip. The case installs easily and also seamlessly slides in and out of backpacks or pockets.
Robust protection
Designed to withstand the rigors of daily use, the OtterBox React Series back cover offers significant drop protection. Its construction is aimed at safeguarding your cell phone from the inevitable drops and bumps, ensuring your device remains in pristine condition. -
Qi compliant
This protective cover doesn't compromise on functionality for safety. It's fully compliant with Qi standards, allowing for wireless charging without the need to remove the case. Enjoy the convenience of charging your device wirelessly, keeping your cell phone protected at all times.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.06 cm x 1.3 cm x 17.01 cm
- 47.37 g
- Clear
- Designed For
- Samsung Galaxy S21 Ultra 5G
- 8.06 cm
- 1.3 cm
- 17.01 cm
- 47.37 g
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop-proof, drop protection
- Cover Type
- Back cover
- Included Accessories
- Clearly Protected screen protector
- Qi
- Designed For
OtterBox React + Clearly Protected Film for Samsung Galaxy S21 Ultra 5G
