OtterGrip Symmetry Series is the sleek grip phone case with an integrated grip that presses flat to slip in and out of pockets and work seamlessly with MagSafe. OtterGrip Symmetry Series is specifically designed for strong alignment and attachment with MagSafe wireless charging and accessories. And precision engineering ensures all your phone’s buttons, features and functions work flawlessly. Capture every moment from group pic to selfie with OtterGrip Symmetry Series.
- Built-in grip for confident and comfortable phone handling
- Grip presses flat with case when not in use
- Sleek case slips easily into pockets
- Snaps to MagSafe with strong alignment and attachment without removing case or grip
- Optimal wireless charging speeds with MagSafe Charger and wireless chargers1
- DROP+ | 3X as many drops as military standard (MIL-STD-810G 516.6)
- Made with more than 50% recycled plastic
- One-piece design installs and removes easily
- Durable protection shields against drops, bumps and fumbles
- Raised edges protect camera and screen
Enhanced durability
Crafted from polycarbonate and synthetic rubber, this case offers a rigid design with reinforced edges, ensuring your cell phone withstands daily use. -
Optimal grip
The non-slip grip feature of the OtterBox OtterGrip Symmetry Series case ensures your device stays securely in your hand, reducing the risk of drops. -
Advanced protection
With MIL-STD-810G 516.6 compliance, this protective cover offers drop+ protection and is shock-absorbent, safeguarding your cell phone from unexpected impacts.
- OtterBox OtterGrip Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.562 cm x 1.34 cm x 16.7 cm
- 58.23 g
- Material
- Polycarbonate, synthetic rubber
- Black
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Plus, 15 Plus
- 8.562 cm
- 1.34 cm
- 16.7 cm
- 58.23 g
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, shock-absorbent
- Cover Type
- Back cover
- Reinforced edges, tactile buttons, rigid case design
- Cover Features
- Non-slip grip
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - lifetime
- Designed For
