OtterBox Micro USB Cable - 3m
Quicklinx: D31GWS00 Mfr#: 78-51152
Meet your favorite charging cable. Upgrade your charging experience with the OtterBox cable. The streamlined, reinforced cable that's made to last.
  • Braided cable
    Improve your charging with the cable that's made to last. It flexes and bends, avoids tangles and knots and is made rugged and durable.
  • Extended strain relief
    Synthetic rubber material is tough and durable. Its innovative design protects the weak spot where cable attaches to connector and supports severe angles against breaking.
OtterBox - USB cable - USB to Micro-USB Type B - 3 m
USB cable
Molded, sync and charge, braided, strain relief, connectors with metal housing, tangle-free
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
Rated Current
2.4 A
1-year warranty
P/N: 77-52922, 77-53030, 77-53123, 77-53124, 77-53317, 77-54845, 77-54846, 77-54995, 77-55403, 77-55404, 77-55767, 77-55999, 77-56088, 77-57243, 77-57622, 77-57674, 77-59001, 77-59018, 77-59086, 77-59088, 77-60243, 77-60244, 78-51304, 78-51306, 78-51374, 78-51375, 78-51452, 78-51475, 78-51511
USB cable
Rated Current
2.4 A
Length
3 m
90.7 g
Connector
1-year warranty
P/N: 77-40486, 77-52026, 77-52028, 77-52922, 77-53030, 77-53123, 77-53124, 77-53173, 77-53317, 77-53923, 77-54845, 77-54846, 77-54995, 77-55403, 77-55404, 77-55767, 77-55999, 77-56088, 77-57243, 77-57622, 77-57674, 77-59001, 77-59018, 77-59086, 77-59088, 77-60243, 77-60244, 78-51304, 78-51306, 78-51374, 78-51375, 78-51452, 78-51475, 78-51511
