Screenless, fearless
LifeProof NÜÜD uses screenless technology for direct display access and true response with your finger or pencil. -
Like a glove
These custom-tailored iPad Pro cases fit tight so your tablet stays thin and light. -
Absolute access
Cameras, fingerprint scanners, volume controls - all of iPad Pro's core features remain the same inside.
- LifeProof NÜÜD Apple iPad Pro 12.9-inch - protective case for tablet
- Product Type
- Protective case for tablet
- Underwater Depth
- Up to 2 m
- 1-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
- Underwater Use
Carrying Case
- Protective case
- Recommended Use
- For tablet
- Protection
- Waterproof, shockproof, dirt-resistant, snowproof
- Underwater Depth
- Up to 2 m
- MIL-STD 810G, IP68
- Max Height of Shock Resistance
- 1.2 m
- 1 year
- Designed For
