OtterBox LifeProof NUUD for 2nd Generation iPad Pro 10.5" -  Black
Quicklinx: D6LXWS00 Mfr#: 77-55825
Take your pro tablet on pro adventures with NÜÜD for iPad Pro (10.5-inch). WaterProof, DirtProof, SnowProof and DropProof, NÜÜD goes everywhere so you can capture everything. Screenless technology lets you touch, pinch and swipe directly on your Multi-touch display - and experience perfect clarity. Plus, the custom design gives you full access to your ports, cameras and controls.
LifeProof NÜÜD - protective waterproof case for tablet
Protective waterproof case for tablet
Screen Size Compatibility
10.5"
19.2 cm x 1.9 cm x 26.8 cm
323 g
Underwater Depth
Up to 2 m
Apple 10.5-inch iPad Air (3rd generation)
19.2 cm
1.9 cm
26.8 cm
323 g
Underwater Use
Carrying Case
Recommended Use
For tablet
10.5"
Protection
Waterproof, dust-resistant, dirt-resistant, drop-proof, snowproof
Underwater Depth
Up to 2 m
IP68, MIL-STD 810G 516.6
Max Height of Shock Resistance
1.2 m
