Live outside the limits and document your deeds with Fre. Fully sealed with a built-in screen cover, this case gives you the freedom to push extremes.
Fre
Fully sealed with a built-in screen cover, this case gives you the freedom to push extremes. -
Form-fitting design
Fre is made to complement your phone's clean lines, adding mere millimeters and grams to its size and weight. -
Zero compromise
Customized for a flawless fit, LifeProof cases keep every button, camera and feature open for action.
- LifeProof FRE - protective waterproof case for mobile phone
- Product Type
- Protective waterproof case for mobile phone
- 8.255 cm x 1.473 cm x 15.672 cm
- 42.4 g
- Avalanche white
- Underwater Depth
- Up to 2 m
- 1-year warranty
- Designed For
- Samsung Galaxy S7
- 8.255 cm
- 1.473 cm
- 15.672 cm
- 42.4 g
- Underwater Use
- Avalanche white
Carrying Case
- Recommended Use
- For mobile phone
- Protection
- Waterproof, shockproof, dirt-resistant, vibration-proof, drop-proof, snowproof
- Underwater Depth
- Up to 2 m
- Included Accessories
- Headphones adapter, microfibre cleaning cloth
- IEC 60529 IP68, MIL-STD 810G 516.6
- 1 year
- Designed For
- Samsung Galaxy S7
