OtterBox LifeProof FRE - Protective Case For Tablet - Avalanche
Quicklinx: BNGLWS00 Mfr#: 77-51012
Fre case is built with everything LifeProof knows about tablet protection.
  • Waterproof
    Featuring a built-in scratch protector, this waterproof iPad mini case keeps your touchscreen flawless and fully interactive.
  • Tiny tablet, tiny case
    While barely adding to the size of your tablet, your iPad mini case seriously steps up your tablet's style.
  • Big features
    Your iPad mini waterproof case works with every feature and function on your tablet, even the fingerprint scanner.
  • Where will you go with Fre
    Life is short, and the world is vast. LifeProof Fre defends your iPad mini from all the dunks, drops and dangers you encounter on your adventures. And, it does it all in a design that you barely notice is there - until you need it.
LifeProof Fre - protective case for tablet
Protective case for tablet
14.7 cm x 1.6 cm x 21.6 cm
132 g
Avalanche
Underwater Depth
Up to 2 m
14.7 cm
1.6 cm
21.6 cm
132 g
Underwater Use
Avalanche
Carrying Case
Protective case
Recommended Use
For tablet
Protection
Waterproof, dirt-resistant, drop-proof
Underwater Depth
Up to 2 m
2 years
