Defender Series Pro XT MagSafe phone case provides advanced defense for your device. Built-in magnets allow MagSafe chargers and accessories snap right to Defender Series Pro XT. The thin, rugged case integrates an antimicrobial additive that helps inhibit microbial growth and helps defend the case exterior against many common bacteria. The premium design displays clean lines with a comfortable grip, the raised edges protect the camera and screen and port covers block dust and dirt. There's even a lanyard attachment integrated into the case for easy carrying. Defender Series Pro XT provides the intense drop protection you need to defend your everyday.
- OtterBox Defender Series XT - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 9.08 cm x 1.32 cm x 17.18 cm
- Material
- Polycarbonate, synthetic rubber, 50% recycled plastic
- Black crystal
- Designed For
- Apple iPhone 14 Plus
- 9.08 cm
- 1.32 cm
- 17.18 cm
- Rugged
- Material
- Black crystal
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Dirt protection, bump protection, drop+ protection, scrape protection
- Cover Type
- Back cover
- DROP+ technology, lanyard attachment
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Designed For
