- OtterBox Defender Series XT - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.417 cm x 15.756 cm x 1.317 cm
- 44.34 g
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Designed For
- Apple iPhone 15
- 8.417 cm
- 15.756 cm
- 1.317 cm
- 44.34 g
- Rugged
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection, dirt protection, bump protection, scrape protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, lanyard attachment, two-piece design, DROP+ technology
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Designed For
- Apple iPhone 15
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HK22 051245 Condition: Customer return - item has been used and shows signs of use |
£13.85 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
