For peak protection, trust Defender Series for MagSafe, our toughest case yet. It features a tri-layer design with a silicone outer cover, rigid inner shell and memory foam backing that work together to deflect whatever damage might come your way — and deliver 7X military standard drop defense. Plus, it's equipped with corners that absorb shock, all-over texturing for greater grip, integrated MagSafe magnets and built-in anchors for connecting phone straps. When you need real defenses, you need Defender Series for MagSafe.
Rugged protection
This protective cover features a tri-layer design that absorbs shock and deflects impacts, ensuring that devices remain secure against accidental drops and rough handling. -
Eco-friendly materials
Made from 45% recycled plastic, this case provides reliable protection while supporting sustainable practices, minimizing environmental impact while ensuring quality. -
Secure grip
Designed with a grippy texture, the OtterBox Defender Series ensures that users can maintain a firm hold on their devices, reducing the likelihood of accidental slips. -
Wireless charging support
The case enables wireless charging compatibility, which offers convenient charging without the need to take the case off, enhancing usability. -
Dust and dirt protection
With integrated port covers and a robust design, the case provides effective protection against dust and dirt, keeping devices clean and functional.
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J5BJ 051195 Condition: Customer return - item has been opened but is in excellent condition |
£9.56 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
